how can I save IV measurement when I use 6221as DC current source and 2182 voltemeter?
I am using 6221 &2182A and I have a little problem.
I need to measure Voltage us Current exactly like the option "DC SWEEP" in the "basic operation" but i cant save the data.
 There is a way to save the data in "DC SWEEP" in the "basic operation"? if not how can I measure simple IV and not advance?
thanks
avner
(3,057 Views)
Please clarify the following: are you using LabVIEW? Which example or VI are you working on? What NI harware are you using?
Ali M
Application Engineer
(3,026 Views)
Currently, I'm working on the same problem. I'm trying to develop an IV measurement VI that uses 6221 as a current sourcde and agilent 34401A as a voltmeter. If completed, which should be on the next week :D, you can enjoy it!
(2,935 Views)
