Speed at parallel procuder loops
Thank you so much vor your Help.
Unfortunately i cannot drag it directly to labview.
One last question (i hope):
In the bottom Loop are two Constants, one at the Shift Register for defined state and one at obtain Queue. Which Type are this, where can i find it in Palette? I think at Queue? Are this Waveform Constants?
Sorry for this noob question
Message 21 of 26
(845 Views)
The one for the shift register looks like an array containing a cluster with 2 numeric (dbl) values.  The constant to the queue looks like a cluster containing 2 of the previously mentioned arrays and a boolean.  You will have to build these up starting from the bottom.
Message 22 of 26
(841 Views)
I managed to drag it, so I assume it was a version problem (apparently the Code Capture Tool has some bug(s) with converting to an older version).
I attach here a backsaved version to 2015.
GCentral
Message 23 of 26
(826 Views)
hm.......
simple question, but so difficult to solve.
This VI is working without any error, but one channel isn´t shown.
There´s no error output.
I think i will take a look to a hardware solution.Perhaps with a converter from temp sensor to 0-5V.
It´s more visible for me then programming
Message 24 of 26
(798 Views)
@Hulk1978 wrote:
hm.......
If you upload what you have and try and explain a bit more what you're (not) seeing and what you expect, I'd be happy to have another look.
GCentral
Message 25 of 26
(776 Views)
I'm Not so much at Office at the Moment.
I tried the Last vi. Program Starts without any Trouble. But the First daq Channel Shows no Output.
Additional i testet IT with probes at different Position.....nothing...empty...but nö failure Code.
The second Task is shown but i doesn't Look Like 10hz.
But at random Tests the shown Task Switch to task1, but never both Tasks at the Same time.
Message 26 of 26
(758 Views)
