Split Waveform
Hi everyone - It's me again 😞
I currently have a waveform which contains data from 4 channels of my DAQ Part.
Now I'd like to strip the 4th channel from this waveform, save that to a file and to display the others.
So my questions are:
* Can I save a waveform directly to a file ?
* How do I rip that 4th channel apart from the whole waveform ?
Thanks for your help
(8,833 Views)
Hi Somnatic
I think you get an array of waveforms from your DAQ-part. So here is a simple example which shows how you extract a signal and how you can store it.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(8,827 Views)
Under Functions  select Signal manipulation then select signal vi.
See jpeg pic
chow xseadog
(8,826 Views)
thx to both of you ...
both versions work as expected 🙂
(8,811 Views)
