Write BMP file does not save file until next time through code LV v6
Hi,  I am using Labview 6 (we own 7 but have not yet migrated)
I am using the Write BMP file vi, Everything works well but the file is not actually written to the disk until the next time the test system is run.  I have read a few posts about closing the file utilizing the refnum from the file but my Write BMP File does not have a refnum connection.
I have attached an image of the code that causes the probelm.  I am not sure if I have to flatten the data or not, it saves exactly what I want just not when I want it.
The name of the file and the path are the  time and date, this all works.
Hope you can help!
Tim
(2,559 Views)
Hi Tim
First please do not upload BMP files, 650KB is a lot of bandwidth !!
(Possible also why no one has so far responded)
Upload as JPG or PNG
Attached is JPG file showing essential blocks to achieve save without rerunning.
Using LV1.1
so unable to save as LV6
chow xseadog
(2,544 Views)
