Split array from FIFO
Hello
I'm running a FIFO from my CRIO 9075 to a RT host on the computer. On the target I have 4 inputs connected to a build array and then FIFO.
How can I split the array up into 4 separate signals on my host?
(3,739 Views)
Accepted by cdonc
Hi cdonc,
the "opposite" of BuildArray is IndexArray...
(3,733 Views)
Thank you, as I understand it I just put the index 0 to read the value of element 0?
(3,726 Views)
Hi cdonc,
yes.
It seems you should also do some LabVIEW 101...
(3,723 Views)
The Index Array can be extended to separate all 4 of your elements.  That would likely be the easiest way for you to do this.
(3,700 Views)
