Split array from FIFO
Hello
I'm running a FIFO from my CRIO 9075 to a RT host on the computer. On the target I have 4 inputs connected to a build array and then FIFO.
How can I split the array up into 4 separate signals on my host?
(3,686 Views)
Accepted by topic author cdonc
Hi cdonc,
the "opposite" of BuildArray is IndexArray...
(3,680 Views)
Thank you, as I understand it I just put the index 0 to read the value of element 0?
(3,673 Views)
Hi cdonc,
yes.
It seems you should also do some LabVIEW 101...
(3,670 Views)
The Index Array can be extended to separate all 4 of your elements.  That would likely be the easiest way for you to do this.
(3,647 Views)
