Split multi line string where next line changes
Hello
The attached screen capture is a multi line string of test results. Each line of the string consists of a date, time and a few numbers which represent the results.
How can I split this string into 2 strings at the arrow indicated, which is where there is a gap of more than 5 minutes between the timestamps?
Message 1 of 9
(7,232 Views)
Accepted by tone5
Here's a start.  Scan the time and subtract it from the previous line.
Jim
Message 2 of 9
(7,201 Views)
Accepted by tone5
To add on to
Cheers
Message 3 of 9
(7,153 Views)
I have maneged to implement this and get it to work, even I don't yet fully understand the string format notation. Many thanks for the suggestion.
Message 4 of 9
(7,118 Views)
The format is a timestamp because it uses "%<" and ">T" to surround the sub-format that defines the timestamp within the string.
Within the timestamp format, there are instances of hour/minute/second/etc values that it looks for within the string. Everything with a "%" in front of it is a numeric value. Everything else is a delimiter specific to the string.
Simple Example:
String: "4:30"
Format String: "%<%H:%M>T"
It uses the colon in the format string to understand where a colon would be found in the timestamp.
Alternatively, you could use "0430" and "%<%H%M>T" and get the same result (but only if the "04" is two digits instead of one)
Cheers
Message 5 of 9
(7,103 Views)
Thanks James
I'm struggling to understand what the "%p" does in "%<%d/%m/%Y %H:%M %p>T".
The Labview help suggests that the %p defines the precision. However when I change the %p to %.2p, or any other value instead of 2, the precision of the result does not change.
The reason I'm looking at this is because I would like the resulting string to look like "dd/mm/yyyy hh:mm:ss", not "dd/mm/yyyy hh:mm:ss.000" i.e. I don't want the 3 decimal places after the seconds.
Am I on the right track in thinking that %p controls the precision of this, or is it done differently for a time vaule?
Message 6 of 9
(7,038 Views)
%p reads the AM/PM part of the timestamp
I usually look here to decode this stuff:
Jim
Message 7 of 9
(7,013 Views)
"resulting string" What resulting string?
From jcarmody example, you have strings that are converted to a Numeric Time Stamp (number of seconds)
Are you talking about a Time Stamp Control that you have placed on your VI?
I think you will also need to use the following format string
%<%m/%d/%Y %H:%M.%S>T
I assume the decimal point in your time strings does not mean fractional minutes, but seconds
Omar
Message 8 of 9
(6,994 Views)
Thanks Omar and jcarmody; that's useful information.
Message 9 of 9
(6,926 Views)
