Split number from data string
I have user inputs like J1.A1 to J1.A20 I want to get the range from the given text 1 to 20,
Kindly share me the logic
Regards
Vikram Kumar P
(5,434 Views)
Accepted by topic author VikramShetty_p
I would use the Scan From String with the format set to "J1.A%d".  You will get the numeric value as an output.
(5,430 Views)
What is it that you are trying to do as a whole?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,380 Views)
I dont understand what is your exact requirement. But I can observe some informations from your post. I made a code snippet (Code made totally in an assumption) with that information. Check out the attached VI and reply.
(5,354 Views)
you mean you just want to extract the numbers?
(5,347 Views)
Thanks to all i got the solution by using scan from string %[a-z,A-Z]%d
Regards
Vikram kumar P
(5,334 Views)
What do you mean library? There is documentation on how the scan from string function works, and the codes to use for defining its operation. What more do you want/need?
Mike...
LabVIEW Champion
(5,201 Views)
