Generate event when focus lost
is there a way to capture an event when a textbox lose focus?
Thanks.
Message 1 of 9
(6,743 Views)
You can generate an user event by checking the "Keyfocus" property of the Text box (String control).
Message 2 of 9
(6,735 Views)
Guillaume D
Message 3 of 9
(6,727 Views)
Hi 1984,
you might support this idea
Message 4 of 9
(6,715 Views)
Just did 🙂
Message 5 of 9
(6,710 Views)
What is it exactly that you are trying to accomplish? Why do you want to generate an event then?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 9
(6,674 Views)
Example: User enters a name of an employee to a string control. Once I detect the "value change" event, I make a search in a DB and list some properties associated to the employee. These params can be modified and saved by the user. It is possible though that the user modifies some of the parameters but the decide to return to the original values. In this case he has to enter a different text into the text field and then reenter the name of the employee. Simply entering to the textfield and pressing enter does not trigger the value change event as the value didnt changed so the default values are not loaded back.
Now you can ask why dont I simply have a load button. The example above is quite simplified. A load button is not feasible, Detecting a lost focus would resolve my problem though. And I can realize this function but query the focus status of the field in every 10ms, I am just wondering if there is a more elegant way to do it.
Message 7 of 9
(6,644 Views)
Accepted by topic author 1984
Yes there is, simply create a key press filter event on that string control and when a tab is entered you fire your (re)load event. Or you could define a custom hot key for that field (like ctrl-D) to set some group of controls to a default state.
What are the complications that would keep a "Load" button from working? Perhaps things are too complicated and you have to simplify things a bit.
Mike...
LabVIEW Champion
Message 8 of 9
(6,635 Views)
Thanks... for this case checking the keypress works just fine! I was thinking about registering custom event, which I did, but it is an overkill as I can just check for keypress.
Message 9 of 9
(6,629 Views)
