Split string with no delimiters
Kinda trite topic, but...
I have a string say 1010002. I need to split it  itno two digits groups - 1 01 00 02, if it's uneven - so MSB stands alone.
Thanks in advance.  🙂
Message 1 of 15
(5,362 Views)
Reverse String + For Loop + String Subset. Put them into VI, mix, cook for three minutes.
Message 2 of 15
(5,346 Views)
You mean something like this?
Message 3 of 15
(5,341 Views)
Accepted by topic author john7
If you check his comment he doesn't want it reversed, does he?
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 4 of 15
(5,331 Views)
strange but from string 1010002 i'm getting only 00 02 using the last methods.
Message 5 of 15
(5,317 Views)
sorry my mistake, last method works just fine. thanks a lot. 🙂
Message 6 of 15
(5,313 Views)
may be in the same topic i can ask another question - how to assemble the resulting array 1 01 00 02  with dots - like 1.1.0.2 ?
Message 7 of 15
(5,301 Views)
Here you go. The 0 case is empty
Message 8 of 15
(5,296 Views)
Splendid. Thanks a lot.
Message 9 of 15
(5,285 Views)
I would do it this way. (wait for Christian to get much simple logic)
You can change the delimeter in whatever way you want.
Message 10 of 15
(5,268 Views)
