Splitting an array element
Hi, I have an array that outputs the data in the form of "10+10i" where the 10 represent the x-axis and the 10i represents the y-axis. I want to get two independent arrays for x-axis and y-axis(without the "i" ), is that possible? thanks for your help.
A.
(4,107 Views)
Accepted by topic author AHmedalnahdi
Numeric >>  Complex palette.   Complex to Re/Im function.
What are you doing with this data.  Because you can feed a complex number directly to an XY graph.
(4,086 Views)
Trying to understand...
Do you have a complex array of type X + Y*i (X being the real part and Y the imaginary part) and do you want to split it you to two independant real arrays ( X and Y)?
If that's the case just use the Complex to Re/Im primitive.
If not please explain in more details what you are trying to achieve.
(4,082 Views)
Thanks guys that solved my problem .Cheers
A.
(4,068 Views)
