Xcontrol is only updating on timeout
Hi
I am using the timeout on an event listener to monitor a network publish shared variable via an xcontrol.
I had to change the timeout on the xcontrol, it appears it not recognising the passed data as new data.
Why is the data not triggering the xcontrol to update?
Seán
(3,313 Views)
Accepted by topic author SeanJ
Oops!  The true value was not wired to the loop when the value changed.  Also, I had to act on data in instead of waiting for data change which didn't seem to work..
It had to wait for the timeout to complete in order to get another variable.  Interesting that the xcontrol queues the values, I going round the bend trying to disable queueing of the Netwok Publish Shared Variable.
(3,283 Views)
