Splitting string into multiple string output
I have this string input from serial port which looks like this:
Voltage20Current10Temperature32
They are all tab delimited.
And I need them to split into three outputs (possibly converted to numerals) -->
Output1 --> 20
Output2 --> 10
Output3 --> 32
Your help will be appreciated. Thanks.
(5,379 Views)
Accepted by ManuSharma
Hi Manu,
Try the attached example.
Nitz
(Give Kudos to good Answers, Mark it as a Solution if your problem is Solved;))
(5,372 Views)
Thank You very much. I really appreciate the help.
(5,363 Views)
I know this is annoying but I have the same problem with serial reads but only with Labview 8.  Would appreciate it if you could offer me a LV8 copy of your solution?
(5,285 Views)
Here it is in LV8.0
Warm regards,
Nitz
(Kudos are always welcome:))
(5,276 Views)
Hey meetjack,
Did you try checking out the code that has been already posted in this thread??
regards,
NitzZ
(5,107 Views)
