Square wave generation
I am trying to generate a square wave as per below attached graph.
I tried using square wave pt by pt VI. But graph is not generating as per requirement. I think timing which i am giving is wrong. Could anyone please help me with solutions?
Graph is Duty cycle vs time.
Regards
Message 1 of 8
(9,864 Views)
Instead of attaching the image, please attach your code.
Is there any specific reason on why you are using the point by point VI?
Message 2 of 8
(9,848 Views)
you should not expect solutions...
When your VI doesn't follow the requirements you made something wrong. Maybe you attach your VI?
Hint: use a For loop on your input array, add up time and create a XY plot using this time scale...
Message 3 of 8
(9,845 Views)
Please find below code. There is no specific reason for using the point by point VI.
Regards
Sagar S
Message 4 of 8
(9,825 Views)
Thank You for the reply. I tried xy graph but it is not generating as square wave.
Regards
Sagar
Message 5 of 8
(9,821 Views)
Accepted by $agar
You are trying to generate a square wave based on a while loop and system timer which would not give you the waveform what you expect. Try using Square Wave.vi by configuring the number of samples upfront, which would give you a perfect square wave of your interest.
Message 6 of 8
(9,801 Views)
Thank you for the reply. I tried with Square Wave.vi . But the desired wave form is not generating.
Please take a look.
Message 7 of 8
(9,797 Views)
Thank You. It works.
Regards
Sagar
Message 8 of 8
(9,782 Views)
