Stand Alone executable
I built the application and would like to deploy the application to other computers operating in remote locations. I built the exe file and the installer package. However, when I try to connect the 9205 device to the field PC and run the application everything is NAN. I included the software to setup the 9205 in the installer as well.
1. What else could I be missing?
The project runs fine on the PC I developed it on, but not using the exe.Smiley Indifferent
Message 1 of 10
(4,530 Views)
Check and make sure the DAQ device has the same designation on the new machine as the machine it was developed on (i.e. Dev1, Dev2, etc)
Randall Pursley
Message 2 of 10
(4,528 Views)
Do you have any settings in Max, for example a name for the 9205 device maybe?
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 3 of 10
(4,527 Views)
I have not named the device. Is that what your asking?
Both responses seem to insist the program is not working because of the PC's lack of ability to recognize the hardware, am I assuming this is where the problem is.
Message 4 of 10
(4,521 Views)
That would be the most obvious place. Compare the Max settings, re-build the application with debugging flags (error output indicators etc), check if you have included VISA/DAQMX etc as required.
Message 5 of 10
(4,519 Views)
Accepted by pistonbones
You most likely need to export your MAX settings and include the file with your installer.  The installer can be configured to automatically import those settings to MAX on the target pc.
Message 6 of 10
(4,511 Views)
I will check the hardware setting.
How do I export the MAX settings and include them in the build? I am not familiar with this procedure.
Message 7 of 10
(4,504 Views)
When I apply voltage to any of the input channels the test hardware screen responds normally...IE 5 volt supply is measured as 5 volts.
Could it just be in the build of the exe file?
Message 8 of 10
(4,499 Views)
Is that on the development machine or on the deployed machine?
Here are a few reference articles about building deployable .exe's with the application builder.
http://zone.ni.com/reference/en-XX/help/371361H-01/lvconcepts/build_checklist/
https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-...
The checklist is a really good way to make sure you've covered all of your bases.
Applications Engineer
CLD Certified
Message 9 of 10
(4,472 Views)
Smiley Very HappyThanks for all the advice...I just needed to include the MAX setting into the installer.
Message 10 of 10
(4,453 Views)
