Stand alone application using DAQ card
Hi all!
After building a stand alone application, I can not run this one because some dlls are missing. In fact those dlls are used by subvis for the daq card. I would like to be able to run my stand alone application on a computer where the daq card is not installed ( the major part of my application do not use the DAQ card. An error message could appear if the user try to use it).
Thanks for your help
Nico
(2,748 Views)
What you can do is move all of the daq VIs out of your main program and load them dynamically when required instead of statically linked. There's a couple of shipping examples that should get you started. One is called Dynamic Load Example and the other is Plug In Example.
(2,748 Views)
