Standard IEC 61850
Does anybody knows whether NI Harwdare & Software are competable with the standard IEC 61850.
It would be nice if someone could send something.
Thanx
(6,144 Views)
Hi metrisys,
As far as I can tell NI does not have any official listing of hardware and software that are compatible with the IEC 61850 protocol.  I don’t believe NI has a direct (plug and play) solution of hardware and software for this protocol.
That being said, most solely digital or analog communication protocols can be implemented on cRIO or one of NI’s other FPGA products often with a non-trivial amount of programming.  Higher level protocols may be a little more straight forward to implement.
For the IEC 61850 protocol, I have heard of another user that was able to determine that it was supported on cRIO.
It would be helpful if anyone that reads this post could take the time to post back with examples of hardware and software they have used with the IEC 61850 protocol.
Jared T.
(6,118 Views)
My company now uses ADI blackfin to deal with IEC61850.
We noticed it would too much to do with NI's SW/HW, and at last we choose DSP as a solution, I would also want to learn if there is any one can provide us a working example.
BTW, we are mainly focus on 61850-9-1 and -9-2, which means for -9-1, as the modules from NI only support operate NIC from higher then TCP/IP level, we have already roll out the possiblilty of implement 61850-9-1 in NI HW platform.
But for -9-2, I beleive there is a chance to implement in NI's nice gears, say, cRIO or PXI, it seems should works for me, but there might jump out lots of problems, it's always not a easy job to to jump to a whole new area.
(5,523 Views)
您好,我是华东理工大学研究生二年级的学生,目前正在进行关于使用Labview仿真IEC61850课题的研究,我想问一下能否使用Labview建立IEC61850中IED的模型,希望嫩购收到版主的回复。谢谢了
(5,430 Views)
Hi WEIGER, You may have better luck in one of these sub-forums:
NI台灣 技術論壇
http://forums.ni.com/ni?category.id=ZHTForum
NI中文技术论坛
http://forums.ni.com/ni?category.id=ZHSForum
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(5,403 Views)
