Start AND stop triggering
I am trying to do a start-and-stop trigger (ie. record while "the button" is
held down by a user). There's a great explanation at
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B123AE0CBB00111EE034080020E74861&p_node=DZ52308&p_submitted=N&p_rank=&p_answer=&p_source=External
As mentioned in many NI articles, the AI Control vi can set the # of
pretrigger scans. In the case of start/stop triggering, the parameter "min #
of pretrigger scans" specifies the minimum number of samples which must be
acquired before a the stop trigger is accepted. The example starts
immediately, then
Instead I wanted to pre-trigger in the classical sense, meaning capture X
samples before the start trigger is received, everything in the middle, an
d
end when the stop trigger is received. Is this possible? The example uses
read/search position input of AI Read, but I don't see a way to get data
from before the start trigger!
-joey
(2,984 Views)
Hi Joey,
Unfortunately, this can't be done. As you know, the Start Trigger is an actual start trigger that begins the acquisition immediately. The Stop Trigger is more of a "Reference" trigger in that it provides a point at which you acquire a specific number of points before the "Reference" point and a certain number after the "Reference" point.
The problem lies in that you need a Stop Trigger to get the pre-trigger values and then you need another trigger afterwards to end the acquisition. You can't configure 2 Stop Triggers. Hope that clears things up a bit.
Ron
(2,984 Views)
