Tab Control Resizing (LabVIEW 7):
Has anyone had any luck with tab control resizing for different monitor resolutions with LabVIEW 7? NI was aware of the bug in LabVIEW 6.1, it seems like it hasn't been fixed.
(3,287 Views)
What exactly was the issue? I haven't run into any problems, but I may just not be building the Front Panel as you are. Let me know when you get a chance. Thanks.
J.R. Allen
(3,287 Views)
This problem occurs when using a tab control. If the tab control covers the entire area of the screen, and you then go to run the VI on another system with a montior of less resolution, the tab control does not resize with the rest of the controls when the VI is configured to "maintain proportions of window for different monitor resolutions" under VI Properties>Window Size. The tabs are not seen on a monitor of less resolution unless you pan around and find them (they are out of the viewable area).
(3,287 Views)
