Start/Pause/Resume Data Acquisition with DAQ assistant within a while loop
Hi everyone,
I'd like to create a VI in which I can start/pause/stop analog data acquisition and data display in a graph indicator with a DAQ assistant in the automatically generated while loop. I have seen that I can use event sructure or case structures. What would you recommend?  Is there an example I can refer to?
ES
Message 1 of 16
(5,983 Views)
Hi ES,
I recommend to use a statemachine!
You already mentioned the states "start", "pause", and "stop". I would add the state "play" to the list…
Message 2 of 16
(5,975 Views)
Dear Gerdw
Do you have a simple example I can refer to?
ES
Message 3 of 16
(5,953 Views)
Hi ES,
LabVIEW comes with a lot of examples, either in the example finder or in the "File" menu -> "New…".
So select the "New…" entry of the file menu and choose "VI" -> "from example" -> "frameworks" -> "pattern" -> "statemachine"!
(The mentioned items are rough translations to English as I use a German LabVIEW version, they can have slightly different names.)
Message 4 of 16
(5,946 Views)
there's no state machine example in the English version of Labview. Maybe is it the Control Design?
Message 5 of 16
(5,907 Views)
There is. Did you check the example finder?? Another advice, forget the DAQ Assistant, and use proper DAQmx VIs in your state machine!
Message 6 of 16
(5,903 Views)
Actually there is a DAQmx example ready to use for the purpose you described.
Open LabVIEW, and go to "Create...", then "Continuous measurement and logging" project. It just does what you need:
EDIT: sorry, wrong entry, you need the one with DAQmx:
 EDIT2:
Message 7 of 16
(5,900 Views)
Hi everyone,
thanks for your suggestions.
I have built a very simple state machine code, in which I can set three values
0 - pause
1-  acquire
2 - stop
I attach the code. I just would like to know if I can set a three-option button which makes me visually select these three states, instead of setting the numeric values 0,1,2.
Thanks again for your help.
ES
Message 8 of 16
(5,891 Views)
Accepted by Emanuele_S
Hi ES,
use an enum to name the states. Then use an enum indicator to indicate the current state…
Message 9 of 16
(5,887 Views)
I did that, it's better than before but I prefer to have three buttons: Pause - Acquire - Stop.
I think it's easy do to this, how can I?
ES
Message 10 of 16
(5,882 Views)
