04-10-2008 07:48 AM
04-10-2008 07:54 AM - edited 04-10-2008 07:55 AM
Hi Kabanga,
what do you thing doesn´t work? Did you check the output of your read serial function? Could it be that there is a carriage return line feed on the end of your received data?
Mike
04-10-2008 08:00 AM
04-10-2008 08:19 AM
Hi Mike
I don't know what is going wrong. Do you think I should disable the "Termination Char" of the "VISA Configure" ?
I thought there is something wrong with my code. I'm not experienced in LabView.
Hi Graziano,
yes there is an interface between the microcontroller and RS232. This is a special electronic component that is called MAX232.
Best regards
Kabanga
04-10-2008 09:14 AM
04-10-2008 09:43 AM
04-10-2008 11:20 AM
04-10-2008 11:26 AM
