Start, stop and restart while loops
Hi, my qustion is i have 2 example a and example b. Example b lets u start counting up in seconds when u want to. as long as the toggle switchs are in correct position. it also lets u start, stop and restart if need be. i want to be able to that with example a, but for some reason the while loop always sets of running independent of what position the the toggle switch. Any help greatly appreciated.
Thanks Stuart
(4,989 Views)
A LabView While loop is like a C do loop: it always executes at least once. It checks the condition at the end of each iteration.
(4,989 Views)
You should build connection in the three switchs. For example, to stop the program, you should connect the stop switch to the inter two loops:(!stop V Boolean), (stop ^ Boolean2).
(4,989 Views)
An example as the attachment.
(4,989 Views)
