when can multi threading not be used
One of the topics for labview certifiation is when can multi threading not be used. Can anyone help me with this one?
(2,952 Views)
Here is one of the documents that talks about this topic and has some useful links:
Why Would I Want to Turn Off Multithreading?
Zvezdana S.
(2,952 Views)
In addition to the other answer that has been posted,
the example that I have first hand experience with is
instrument control. There is only one instrument out
there. Multi-threading could allow a second thread to
attempt instrument I/O before the first one is
finished. You could get unexpected results or a hang.
File I/O could have the same problem if two threads
attempt to write to the same file at the same time.
You could still have multi-threading in these cases,
but you need some flag that says "wait, I'm busy" to
the second thread.
Les.Hammer@CompleteTest.com
(2,952 Views)
