Starting DAQ assistant earlier than main program
I would need to start acquiring data via the DAQ assistant module 100ms before my main program in the while loop starts (see pic attached). How could I simply achieve that (without having to include the DAQ assistant in the while loop itself)?
Thanks for your help,
Thibault.
(3,306 Views)
Accepted by Thibault_Prevost
Put a flat sequence frame between the DAQ mx start and the while loop.  Wire the error wires through it.  Put a 100ms Wait function in the frame.
(3,296 Views)
Or use the "time delay" express VI, which has error wires, and set the delay to 100msec...
(choose "view as icon" to make your block diagram a bit nicer to look at)
(3,294 Views)
The flat sequence thing works beautifully: thanks!
Thibault
(3,275 Views)
Then mark Raven's answer as the solution - not your thank you.
Click on 'Options' to change the marked solution.
(3,270 Views)
Oops... yes... sorry!
T
(3,265 Views)
