Starting events at specific times of the day?
Hi All,
I would like to trigger events at specific times of the day, and would like suggestions on how the attached vi can be improved.
The events will drive a state machine, as per this example by FuManWho:
https://forums.ni.com/t5/Example-Programs/UI-Producer-Loop-with-State-Machine-Consumer-Loop-Using-La...
The vi works (as long as the consumer is slower than the producer), but I'm sure there is a better way of doing this! Custom events? QMH?
Many thanks
Graham
Message 1 of 21
(6,394 Views)
Accepted by grahamwebb
Hi graham,
just a suggestion:
You could put those FOR loops into the timeout event of your event structure…
Message 2 of 21
(6,392 Views)
Oh I like that. Thanks.
I did have them in the timeout at one stage but moved them around to get over a different problem - my event queue was filling up (to 99 events) in the time the 60 seconds the test condition was true. Limiting the queue size and adding delays worked but I didn't like stalling the consumer to get around that.
Message 3 of 21
(6,385 Views)
Hi Graham,
You surely want to generate just one event when the conditions switches to TRUE!
So you need to include a comparison to check for changed conditions…
Message 4 of 21
(6,376 Views)
Yes (at least I think so!). The event would be something like play mp3 file, switch light on, boil kettle etc. Single discrete events that begin at that time.
Message 5 of 21
(6,364 Views)
What you should do is add a shift register to hold the current comparisons.  Then you can do a if(current Value == TRUE AND previous value == FALSE) {do action}.
GCentral
Message 6 of 21
(6,349 Views)
Do you really need to check for a timeout every 10 ms? That seems extremely fast for the types of events you are triggering.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 21
(6,327 Views)
Since I can't open the VI (Installing 2017 now) and it is in 2017
Why not use "Value Changed.vim" on the Time Date record.(Day, Hour, Month, Minute) element as appropriate?
Hint: for bonus points you can even add a "Quotient & Remainder" to a counter that increments every (Whatever)
Anyone up to Whip in a simple example firing a "User Event" every n Seconds? (Wire control "n" to the divisor of Q&R test R=0, if so generate "User Event"
🙂 Bonus points if the user event data type contains a date-time record
Message 8 of 21
(6,320 Views)
@GerdW wrote:
Hi graham,
just a suggestion:
Also be aware of that issue with DST and the witching hour of 2:00 AM. One day of the year there are two hours that are "2:00 AM" and another day where there is NO "2:00 AM". As long as the trigger times are not in that window, just ignore me.
Ben
Message 9 of 21
(6,315 Views)
@Ben wrote:
@GerdW wrote:
Hi graham,
just a suggestion:
Ben
Cast "To UTC" and ingore Ben this time.   😮
Message 10 of 21
(6,305 Views)
