Starting time at X-axis not changing with time
Hello, I have question regarding x-axis auto scaling. I need my x-axis to save everything during my test, I tried many things like auto scale, non auto scale, x-scale editable, x-scale loose fit but still the starting point of the test is changing with time. please see picture for something similar to what I need to get and thank you. Capture.JPG
Message 1 of 8
(491 Views)
Accepted by Omar-Abdelhameed
Hi Omar,
Your question is NOT about "x axis auto-scaling", it's about the amount of data to be presented in your chart!
The x axis does NOT "save" everything, it just indicates the range of data you present in the plot(s)…
Did you change the chart history length?
There are differences between charts and graphs in LabVIEW: charts have a history buffer, graphs don't have it.
As the history is limited in length the x axis can only show a limited range of data. As soon as older data are removed from the history buffer the x axis will start to change its start value…
Suggestion: use a graph and keep your own data buffer. Learn about decimating data before plotting them as it DOESN'T make sense to plot a lot more samples then the width of the graph in pixels…
Message 2 of 8
(478 Views)
Thanks for your response. yes, I need to change the data presented on the chart. I didn't mean save, I meant indicates the data only. How can I change the chart history length to be at maximum ?
Message 3 of 8
(469 Views)
Thank you, I done it changing chart history from properties.
Message 4 of 8
(459 Views)
Hi Omar,
Be careful with setting the chart history length to "maximum": you can easily crash your VI by doing so.
Generic advice: use a SCC tool to keep a revision history of your code…
Message 5 of 8
(449 Views)
Thank you GerdW.
Message 6 of 8
(442 Views)
I VI crashed but it's okay since I have a copy of it. I am using LabVIEW 2024 32 bit and am not able to make the chart history length bigger than 1024 and if I try that, the VI crash. How I can increase it without any crash?
Message 7 of 8
(391 Views)
Hi Omar,
Using a history buffer of 1024 elements usually is no problem - unless you stuff larger waveforms into each element.
Using the DDT datatype isn't helpful, too…
Replace that MergeSignal node by a simple Bundle cluster node!
I repeat my suggestion:
  • Use your own data buffer (aka shift register!) to hold data.
  • Decimate data before plotting in a graph. It still doesn't make sense to plot more than 1024 samples (per plot) on a graph with only ~500 width…
Message 8 of 8
(385 Views)
