State Machine
 Hi all
How do you make a single state to process code only  on the second time that particular state is called. For example in the code attached how would you make the "log state" execute after double the log time.
Message 1 of 22
(6,192 Views)
So you're logging every 125 ms on the timeout event? And you want to continue logging every timeout event, but bypass the first timeout event?
If that's what you're tring to do you could use the First Call? function to ignore the first time that event is called.
Eric
Message 2 of 22
(6,190 Views)
Hi Charles,
so you want a StateMachine that doesn't work like a StateMachine???
When you don't want to execute a state then don't call it! Only go to "Log" state when all conditions are met...
Message 3 of 22
(6,189 Views)
Oh, you're actually acquiring every 125 ms and logging every 15 s. I still think you can use First Call? for this.
Message 4 of 22
(6,182 Views)
Thanks guys
Egraham , your latter presumption is actually correct. I will try your solution first.
Message 5 of 22
(6,178 Views)
Maybe  I should state the root of my problem. I have one state that executes after double the time of another so I'd like to use the same timer for both states. I am thinking this is much simpler than trying to use multiple timers which i really don't know  how to do.
Message 6 of 22
(6,177 Views)
Hi Charles,
you don't need two or more timers. You simply have to make two checks before calling the log state ("time over" & "not the first run")...
Message 7 of 22
(6,173 Views)
Hmm... I guess GerdW understands what you're trying to do. I'm still not understanding. The same timer used for multiple states could be pulled out of the case structure and fed in. If one requires double the time, just multiply the output by 2.
Message 8 of 22
(6,173 Views)
Accepted by Charles.m
Correction... you would have to set the timer to the maximum state time and execute the case requiring half the time on increments of half of what the timer was set for.
Message 9 of 22
(6,171 Views)
Why not remove the actual code from the timeout event and use user defined events. Create an event for each of your states and then the timeout event will simply compare the time to see which events should be fired. You can use the current time or tick count to track time. A shift register with a cluster of your various start times for tracking the individual times themselves would work. This would work much more like a true state machine. Also, your Stop event can handle the cleanup and there is no reason to post another state.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 10 of 22
(6,157 Views)
