State machine: event triggered by elapsed time
I have a program where I would like one of the events to start when a pre-determined elapsed time has gone by. I tried to trigger the event with a boolean: Elapsed time = given value is true, then go to that event. However I cannot get it to work. I am attaching the code but just in case it does not open, I am also attaching a picture of the relevant portion in the block diagram. Any advise?
(1,895 Views)
Accepted by topic author awayllace
To trigger the event structure you have to use a value signaling property node, not the terminal nor a local variable.
(1,840 Views)
Kudos for a link to my tag Grandmas house thread!
Extra kudos if you post the small child in the back seat as a dynamic event!
@OP,  you have to break the data dependency between the parallel loops!
(1,828 Views)
Thank you so much! That worked!
(1,785 Views)
