11-27-2020 03:02 PM
another problem with Labview, I need to plot transmittance chart H(f) using White Noise, PSD and IIR filter with sepcifications like on this photo below (with property chart).
I check the probes and there's no any f0 values, I also check errors, but still nothing.
Any advice for me? 🙂
11-30-2020 01:39 AM - edited 11-30-2020 01:40 AM
Hi Lukasz,
@lukaszc331 wrote:
Any advice for me?
Advice:
Don't use an arbitrary ramp to simulate a X axis: this will not make up any sense for your signal…
See this:
There is an amplitude for f0, it's just quite small as can be seen in your image!
You apply a bandpass filter, using 100Hz & 500Hz as filter limits. Which amplitudes do you expect outside this frequency band?
12-02-2020 10:17 AM
Yes, of course outside its 0. But I need to get Wafeform like this:
Y - transmittance, X - frequency
New VI below.
