PSD with White Noise
another problem with Labview, I need to plot transmittance chart H(f) using White Noise, PSD and IIR filter with sepcifications like on this photo below (with property chart).
I check the probes and there's no any f0 values, I also check errors, but still nothing.
Any advice for me? 🙂
(1,516 Views)
Hi Lukasz,
@lukaszc331 wrote:
Any advice for me?
Advice:
Don't use an arbitrary ramp to simulate a X axis: this will not make up any sense for your signal…
See this:
There is an amplitude for f0, it's just quite small as can be seen in your image!
You apply a bandpass filter, using 100Hz & 500Hz as filter limits. Which amplitudes do you expect outside this frequency band?
(1,457 Views)
Yes, of course outside its 0. But I need to get Wafeform like this:
Y - transmittance, X - frequency
New VI below.
(1,429 Views)
