Statistics Express Kurtosis inconistency Labview 2011 (Bug 215683)
Hi All,
I am currently working with a data collection program from which I need to output the skew and kurtosis values for an array of 30 data points. As I was already using the Statistics Express VI to calculate mean, s.d. etc. I just added the skew and kurtosis outputs to that VI. I then set up a basic VI to generate a 1D array of random numbers to let me compare the Express VI to the skew and kurtosis VI on the mathematics > probability and stats. palette.
The skew and kurtosis values are inconsistent between the two VIs. If I calculate the skew and kurtosis by hand I can see that the non-express VI appears to be giving the correct answer. I did some digging and found that this has been labelled as bug no. 215683 and is described as having been fixed as part of Labview 2011. I am running Labview 2011 with SP1 so I'm not quite sure why the two VIs are still inconsistent.
I realise that I can simply use the VI which is giving the correct answer but I am curious as to why a bug which should be fixed still appears to be active in my version of Labview.
Any thoughts/ input would be greatly appreciated.
Many thanks in advance
(3,375 Views)
Hi. Have you tried running this on a newer version of LabVIEW. This may have been repaired in a later version of LabVIEW.
(3,329 Views)
Thanks for the reply, unfortunately I do not have access to a newer version of Labview. In this white paper, the bug is described as having been fixed between Labview 2010 and Labview 2011 which is why I'm a little confused as to why it is still occurring in my Labview 2011 installation.
(3,322 Views)
Hi cat,
why don't you get rid of that buggy (as it seems) ExpressVI?
The remaining data (StDev, variance) are provided by just another function from math->statistics palette…
You can also opne the ExpressVI to see, how it calculates those data and why it does produce different results!
(3,314 Views)
Hi. I have managed to replicate the issue in LabVIEW 2013 so it appears this bug is still present. I will get in touch with our r&d team with regards to this bug and make sure this gets looked into by our developers. Are you happy to use the regular VIs in the meantime?
(3,308 Views)
Hi there,
I have added the separate VIs into my program. Fortunately, as I'm fairly new to Labview, I've been checking that calculation VIs give me the correct answers so that I can understand the possibility of things like rounding errors occuring (and because it shows me how to build calculations of my own).
Thanks again for the help.
(3,301 Views)
Hi catofthefens,
The fix for bug 215683 was to add the non-express VI on statistics palette.   The express VI assumes the input sequence is a complete population to calculate the skewness and kurtosis.
The non-express VI gives the option between population and samples.  And the default option is samples, which is a more valid option in other software.
We will add more description in the document to help user understand the difference between these VIs.
Michael
(3,289 Views)
