Stepped Limit Lines
Hey I'm looking to create limit lines for an insertion loss test. The spec limits to be used come from a string containing (.34;1;.82;10;1.15;18;1.44;26.5;1.85;40) basically meaning a .34 limit line @ 1, a .82 limit line @10, etc...essentially creating a segmented or stepped spec line. Any direction on how I might be able to do this would be much appreciated. Thank you!
Message 1 of 15
(4,904 Views)
How to do what?  You haven't told us how LabVIEW plays into this.
Are your questions about interfacing with the hardware?  How to display lines on a graph?  How to architect an entire application for you based on a few sentence specification?
Message 2 of 15
(4,892 Views)
This link should be of use to you.  Happy drawing!  🙂
Bill
CLD
(Mid-Level minion.)
Message 3 of 15
(4,881 Views)
I think he just wants to plot some S-Param data with some limit lines.  I'm assuming in and out of band specs.  🙂
Bill
CLD
(Mid-Level minion.)
Message 4 of 15
(4,876 Views)
 I have a string coming in from a SQL database, that string contains specs in dB with corresponding frequencies. I was wondering if possible there was a way to take each value from that string in order to create an array that will later be used to create spec lines for my insertion loss test....in LabVIEW.
Message 5 of 15
(4,869 Views)
I'm no expert with SQL, but it should be very easy to do that.  I'm guessing you're having trouble with the SQL part?
Bill
CLD
(Mid-Level minion.)
Message 6 of 15
(4,851 Views)
No I'm not having trouble with SQL, I'm able to pull the string with the specs. My issue is I dont know how to take the values (.34;1;.82;10;1.15;18;1.44;26.5;1.85;40) contained in the string and break them into each individual spec value.
Message 7 of 15
(4,775 Views)
Hi Zz,
use SpreadsheetStringToArray, then Decimate1DArray to get X and Y components…
Message 8 of 15
(4,769 Views)
GerdW,
Thats what I had thought to use originally(minus the decimate 1d array). I used the spreadsheet string to array function followe by the decimate 1D array. the string  (.34;1;.82;10;1.15;18;1.44;26.5;1.85;40) enters into the spreadsheet string to array function, and then outputs 0...as if nothing was even inputted. Attached is a screen shot of my setup as well as probes documenting the data flow.
Message 9 of 15
(4,759 Views)
You have to specify the correct delimiter for the string to array function. The default is a tab, which you don't have in the string. Please turn on Context Help and leave it turned on.
Message 10 of 15
(4,743 Views)
