Stepper Motor with Linear Stage (Position Control and Data Acquisition)
Hey All,
So.. I've attached a stepper motor to a linear stage and so far it's working pretty well.  Using a stepper motor driver from Pololu, I've simplified the control of the motor by just using output pulses from the counter output of a PXI-6143.  I've tested the motor using the Pulse Train examples in LabVIEW and all is working well.
My goal now is to allow the user to collect data from a pressure sensor, attached to the linear stage, every X number of steps.  From what I can tell so far, and please correct me if I'm wrong, the motor step movement is synchronised with the pulse train input.  That is to say, if I give the motor a 200 step pulse train, the pulse train ouput is completed at the exact time the motor has moved 200 steps.  From this, I've created a VI that moves the motor X steps, aquires the data point, and then repeats this process for the required amount of data points.  The problem with this is that the motor movement is not continuous; it stops for a split second to take the data point.
How can I have labview ouput a pulse train of say 1000 steps and record a data point every 50 steps?
Two ideas that came to mind were:
1. Use the counter input port on the card to count the pulses being sent to the motor.
2. Use an encoder connected to the motor shaft.
I wanted to stay away from theses ideas though since they require resources from the DAQ card.
Ryan
(3,153 Views)
Hi Ryan,
Just to cover all the bases, what version of LabVIEW are you using and can you attach your VI? Initially your ideas sound like they should work, do you expect to be nearly maxing out the DAQ?
Thank you,
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(3,124 Views)
