where are daqmx files stored on real time target?
I am working on an application that will be embedded in a RT desktop target.  To make the system easier to maintain in the future, I would like to be able to generate a DAQmx task programatically from the *.ini file exported from MAX.  This way, users don't have to know what my code is doing in order to recalibrate sensors or manage new hardware; they only have to know how to use MAX and where to store the config files on the target.
Where are daqmx task, channel, and scale information stored on a RT target?  I've been through the files on the target looking for something that contains my task data but have found nothing, though dropping a system property node into a VI running on the target will give a correct list of the tasks that I have configured.  (The project that contains the aforementioned VI does not have the tasks in it ie: I did not import them to the project.)
Is there a utility that will run on the RT target that can generate a task at run time from the exported *.ini files?
CLAD
(2,297 Views)
Accepted by topic author testingHotAir
Exahustive keyword searching brought me to an answer on the forums.  I'll post a brief summary here in case anyone else uses the same keywords as I have.
1.  Export config file from MAX
2.  Write a VI that uses the tools in the System Management pallette to upload the configuration to the real-time target.
3.  Profit.
In my case, the VI I wrote to upload the DAQmx config also generates the config files for the VIs on the host and target side, so everybody knows what the tasks are called.
CLAD
(2,274 Views)
