Stop not working
It would be so much easier to explain if I could post all my code but I will give it a try:d In frame (1)of the stacked sequence it uses the CAN to get the checksum value (this happened with no issues) In frame (2) the Boolean indicator for the true/false case structure that I posted a picture was true so that frame should execute In frame (3) the CAN device should be reading another value, but can't and get the error "Error -1074388956 occurred at Ni-CAN Write CAN Network Interface Object (ncWritenet.vi) Verify that he Open function succeeded. If in frame (2) the stop button or popup worked correctly then I shouldn't have even gotten to frame (3), at least this was my best guess. I am not surprised the Open function wouldn't succeed since I don't re-open the CAN device in frame (3) since it should already be open unless there is an error and then the above mentioned stop is in place. I am hoping you can give me some insight since this is stumping me bad!
-ncm
Message 11 of 13
(1,661 Views)
Have you run highlight execution to see what values are being set where?  This might help you understand where logic is causing issues.
Message 12 of 13
(1,646 Views)
Accepted by ncm
Thank you everyone for your replies. I spoke with tech support and apparently there can be issues with upgrading and just copying and pasting. I had to delete and then re-add my popups for going to 2010 LV to 2015 LV. The popups aren't the only issues (some other engineers have had troubles with other icons with upgrading even when they are the same and not legacy icons). One change was I didn't connect the T/F to the 'STOP' icon so that it will stop even if a popup doesn't appear.
-ncm
Message 13 of 13
(1,605 Views)
