Stop stepping of motor when senses digital pulse from light reflective sensor
Hi there,
I am currently doing my school project and i managed to do the stepping of the motor through the digital port of the USB 6008 by setting the boolean output in a while loop with use-cases but now i faced a problem because i am required to use it with a reflective sensor and stop the motor when it senses a digital pulse.The sensor is configured as a counter using PFI0 on the USB 6008 with a circuit which will send in a digital pulse to the daq.
How do i go about stopping the motor when the reflective sensor is blocked and then start the stepping again when it's not blocked
Message 1 of 8
(3,261 Views)
Do you really want to work with this like a digital pulse, or like a digital input?
I would treat it like a digital input where you read the input and it is either true or false depending on the presence of the object detected by the reflective sensor.
Message 2 of 8
(3,259 Views)
thanks for the reply but i could not get the boolean data from the daqmxRead. I put a indicator at the data line and it's in number value not boolean
Message 3 of 8
(3,251 Views)
Post your VI.  It is probably a matter of the task not being configured properly, or the DAQmx Read VI not configured properly.
Message 4 of 8
(3,245 Views)
Attached is the VI you requested please advise thanks
Message 5 of 8
(3,238 Views)
Accepted by bloodxrage
The upper task is still set up as a counter task.  You need to change the DAQmx create channel as a digital input, and the DAQmx read as a digital boolean 1 channel 1 sample.
Message 6 of 8
(3,225 Views)
i had already change it to digital input and connect the circuit to the digital port on the daq but it keeps on reading a true even though i blocked the sensor.
Message 7 of 8
(3,204 Views)
sorry ignore my last post i was successful in doing so i had not change the physical input channel to the digital port thanks for the help
Message 8 of 8
(3,201 Views)
