Store Plot Intersect values
Hye
I need to be able to build a table with values where my white plot intersects my red plot two times and measures the time the green plot is at 1.
As you can see you manually have to change the Slider to observe the situation.
See the attached VI
(3,389 Views)
Try something like this....
You can easily change it to form a table instead of a simple string with one time/line. Make changes to display seconds instead of milliseconds or differently formatted times. Modify as needed....
(3,374 Views)
Altenbech!
Thanks for that.
Thats fine for storing the timer values.
 Still, how to get and store the intercept values between white and red plots in addition to getting the milli second timer value
(3,368 Views)
Might have to replace the up value string with the Build Table with columns and rows
(3,367 Views)
Accepted by topic author weeke
Did you figure it out?
Here's a quick draft how it could be done....
(3,347 Views)
This is something similar to what i wanted.
I need to play with it a little bit.
Thanks for that
(3,337 Views)
