Store new values of array in new row while old ones remain in previous rows
I'm a student of Elctronics engineering. I have made a VI where I change the values from numeric controls and it saves it as an array.
I want to store couple of new values in new row of this array.
I have attached a VI where I can change values from numeric control and also the number of rows from another control. But when I change the values, all the values of output array change including values in previous row. I want those rows to be unchanged and only new row to update.
Help needed.
Message 1 of 19
(3,373 Views)
Is this the same issue you are facing here?
Message 2 of 19
(3,366 Views)
Do I get it right that you want to create a two dimensional array with four collumns and a variable number of rows where the elements are defined row by row?
Message 3 of 19
(3,362 Views)
I want 4 number of rows. But I want rows which I can change from a numeric control and every time I change row and change my input, the new elements must be saved in new row while the elements in old rows remain same.
Message 4 of 19
(3,349 Views)
The thing with 2D arrays is that all of the rows have to have the same number of colums.  So if you add an element to a row, then all of the rows need to add an element.  If you are totally set with 4 rows (no possibility of expansion), then create a cluster of 4 arrays.  Then each array can vary in length as much as they want.
Message 5 of 19
(3,321 Views)
Accepted by NapDynamite
If I get it right you always want 4 collumns. If so one 2D array will do the trick (see attached VI), if not crossrulz' solution should work.
Message 6 of 19
(3,312 Views)
Thumbs up Bert, thank you so much. This is exactly what I needed.
Message 7 of 19
(3,298 Views)
Come on! Don't use greedy loops in example code. It encourages bad coding habits!
(Also one while loop would be completely sufficient here. Don't overcomplicate things)
Message 8 of 19
(3,294 Views)
Just to make Christian a little happier...
Message 9 of 19
(3,289 Views)
I indeed forgot to implement a Wait. But what do you mean with overcomplicating things? I don't think the event structure makes it that less complicated.
Message 10 of 19
(3,272 Views)
