Storing into a string the content of a folder using zip compression
there must be a mistake somewhere ... if i run the vi  using the binary blocks... the original zip file is 12 Mb and the re-builded one is 1byte... I think I'm not reading the original zip file properly.
Message 11 of 14
(685 Views)
The binary read function has a 'count' input that defaults to a count of 1 byte when you leave it unwired.  Instead, wire in the special value -1 to read the entire contents all at once.
(See the function's online "Detailed Help" for more info.  I would recommend it as a good habit to also define the 'data type' input, even though it defaults to string which is what you happen to want this time.  This will provide greater clarity for anyone who uses or copies this code in the future, including your own future self.).
-Kevin P
Message 12 of 14
(679 Views)
Accepted by topic author francescofabbro
Message 13 of 14
(673 Views)
thats' the key!
now it's working!
Message 14 of 14
(663 Views)
