Strange Block Diagram behavior
[deleted]
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 20
(1,253 Views)
@billko wrote:
I hate autogrow so much I call it "auto-groan".
I also hate auto tool selection.  It's like I'm trying to work on a car and a monkey keeps changing the tool in my hand.
Message 12 of 20
(1,248 Views)
That looks like you actually have a group of boolean constants and a group of local variables. You could post the VI so we could tell if they are grouped or nor... Can't tell from a picture.
Generally, you could get away with 1 boolean constant and a Negate. I honestly don't recall the last time I used a local (I have used them but it isn't often.)  This suggests that you have bad habits that you hide to make the bd prettier without really "getting" best practices.
Message 13 of 20
(1,236 Views)
Yeah, I'm sure I have plenty of bad habits!  One of them is not explaining myself well enough!  That image was simply an example to show how the local variables moved relative to the boolean constants.  For the record, it looks like other components also move (as they should).  The following is another example.  I put together an illustrative circuit with some constantsm controls, indicators, property nodes and a few other elements:
By changing case to the false case:
and then doing a control drag (in the other case as shown) as the arrow indicates:
It is clear the constants (crudely circled here) have remained in the same place, while the rest of the components have moved as expected.
Apologies for my poor explanation previously.
Anyway, I'm curious to learn how to avoid using local variables?  Do you use references?
Also not sure what you mean by 'negate'.
Any help to improve my programming is much appreciated.
Mark
Message 14 of 20
(1,224 Views)
I typically just use a wire. 😄 (and maybe a shift register or feedback node)
I am not sure if you are just messing with us, but an "=true" is the same as a wire and just returns the control input unchanged.
Message 15 of 20
(1,209 Views)
Mark
This is exactly what I described in my first post.
Bill
CLD
(Mid-Level minion.)
Message 16 of 20
(1,200 Views)
Though it behaves the same with and without Autogrow enabled on the structure
Qestit Systems
Message 17 of 20
(1,181 Views)
I've had this happen fairly often when expanding code. Effed up some VIs something horrible, but i only noticed it later when i couldn't undo the changes anymore.
Message 18 of 20
(1,165 Views)
That's just a thrown together fragment to demonstrate that the constants remain in place and the other circuit elements move during the ctrl-drag we were discussing.
Message 19 of 20
(1,161 Views)
Yeah, I just missed the point that it had to be in another case.
Message 20 of 20
(1,159 Views)
