Strange array of ctl behaviour
Why do I have to change a value in an array of .ctl before the current index gets usable?
If I dont change a value after startup the default values arent used.
Actor Framework
Message 1 of 11
(2,508 Views)
Because your array is empty. Indexing an element from an empty array just gives you default values…
Message 2 of 11
(2,500 Views)
I have overwritten the default values in the ctl's elements. That is why Labview displays these values, but forwards the types(uint,int) default values instead. This makes hardly sense.
Actor Framework
Message 3 of 11
(2,495 Views)
Please downconvert your example for LV2020 (File->Save for previous)…
A typedefinition (ctl) only defines the type, but not the value…
Message 4 of 11
(2,486 Views)
Yes it does. I cannot look at your code because the version is newer than what I have, but your diagram picture certainly raises a lot of eyebrows.
  • Indexing out an element that does not exist gives you the default value for the datatype, not the default value for the element. A default value is a property of the terminal (control or indicator), not of the data in the wire. If would be really confusing to return real-looking data when indexing out of bounds.
  • Why do you read from a local variable instead of the array terminal?
  • What's the purpose of the error wire?
  • Why do you need a greedy loop that cannot be stopped?
  • You can easily add a tiny little bit of code that returns something specific if you try to get an element that does not exists. Instead of data, you should return an error of course. You can easily make the array have a default values where the size is not zero.
Message 5 of 11
(2,466 Views)
For me it is a secret how one can initialize an array with a ctl's elements default values programatically.
Actor Framework
Message 6 of 11
(2,447 Views)
Get rid of the local.  You don't need it the terminal is right there and unwired.
Get some type of timing in that loop and a stop condition!  If you want the vi to respond to user input....use a value change event case.
The control is not behaving strangely,  the programmer is!
Message 7 of 11
(2,446 Views)
The more experience you have, the more likely that what you want the program to do and what you tell it to do will converge.  Hopefully.
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(2,429 Views)
On a side note, your question does have some validity!
 Have a look at my 10 year old idea and its comments here. 😄
Message 9 of 11
(2,426 Views)
Accepted by topic author Quiztus2
One possibility:
Message 10 of 11
(2,411 Views)
