07-19-2022 03:27 AM
Why do I have to change a value in an array of .ctl before the current index gets usable?
If I dont change a value after startup the default values arent used.
Solved! Go to Solution.
07-19-2022 03:38 AM
Because your array is empty. Indexing an element from an empty array just gives you default values…
07-19-2022 03:47 AM
I have overwritten the default values in the ctl's elements. That is why Labview displays these values, but forwards the types(uint,int) default values instead. This makes hardly sense.
07-19-2022 04:27 AM - edited 07-19-2022 04:29 AM
Please downconvert your example for LV2020 (File->Save for previous)…
A typedefinition (ctl) only defines the type, but not the value…
07-19-2022 08:07 AM - edited 07-19-2022 08:10 AM
Yes it does. I cannot look at your code because the version is newer than what I have, but your diagram picture certainly raises a lot of eyebrows.
07-19-2022 09:07 AM
For me it is a secret how one can initialize an array with a ctl's elements default values programatically.
07-19-2022 09:10 AM - edited 07-19-2022 09:15 AM
Get rid of the local. You don't need it the terminal is right there and unwired.
Get some type of timing in that loop and a stop condition! If you want the vi to respond to user input....use a value change event case.
The control is not behaving strangely, the programmer is!
07-19-2022 09:32 AM
The more experience you have, the more likely that what you want the program to do and what you tell it to do will converge. Hopefully.
07-19-2022 09:33 AM
On a side note, your question does have some validity!
Have a look at my 10 year old idea and its comments here. 😄
07-19-2022 09:56 AM - edited 07-19-2022 10:05 AM
One possibility:
