Strange result from frequency analysis!!!
I want to see how well does the non-parametric estimation of System Identification Toolkit work. So I made a PT2 transfer function in Matlab/simulink, gave my input signal as Chirp and got my output signal. After that, I read these signals in labview and made a bode-diagram by using the Freq Resp function. The result was quite strange. I have drawn a bode-diagram in Matlab with those input and output signals, the result is correct. So, I do not understand why it does not work with labview. Is there any reason for that? What are the tips for doing frequency analysis in labview? Because later I will do that for my real system, I really want to be sure it works and I got the right results. Another thing is, whether it is possible in labview to define a transfer function, then let my input signal go throught it and get the output signal, like what can be done in matlab/simulink? How can I do it in the easiest way? Thanks a lot!!!!
(3,194 Views)
Duplicate post, see here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=259997
(3,176 Views)
If you cannot answer my question, then at least you can keep quiet. The reason that change to another title is that I want people to be interest with my question. Everyone who ask a question want to get an answer immediatly.Right?
(3,155 Views)
Hi yuwu,
yeah, and other people searching for the same topic would like to get all answers in one place...
(3,150 Views)
Yuwu,
Posting duplicate questions is just plain rude. Not only that, you responded with a bad rating and an equally rude comment. I don't think you deserve anyone's help.
(3,140 Views)
