Stream data to disk (LabVIEW RT and NI PXI-5122)
I'm planning to acquire a signal at a rate of 20MS/s during 10 Minutes. I thought about buying a PXI Chassis containing a digitizer PXI-5122 and a controler PXI-8174 running LabVIEW RT. Is it possible to stream the data to disk or to another HOST PC with those requirements ? Does anybody have onother hardware solution ?
Thanks in advance with any answer ?
(3,045 Views)
LV-RT is not required unless you are doing something else in addition to the acquisition.
I will assume you will only be collecting one channel of data.
If you do some math you will see that the acquistion alone will eat up a large portion of the PXI bus bandwidth.
If you throw in saving to disk at the same time, you are going to be pushing things a bit.
If you settle for just acquiring the data into memory durring the 10 minutes (!) and then writing the buffer to file after the acq is done, I believe this task is do-able! The OS you use to run the app really will not matter much provided you code allocates enough memory ahead of time.
I would start by doing a quick test where an acq is started and the I/O is configured to read 1 or 2 minutes of data.
Yes the app will "hang" while waiting for the data. If this works I would then repeat the test for the desired 10 minutes. Your system will need about 512M of memory just to buffer the data. Less than that will present problems.
If the test app does OK on the above mentioned (repeated multiple times) test, you may be in buisness. You will just have to write the 1/2 Gig file and you are done.
If the above fails, do not give up! First keep us informed of how things are going and we may be able to get around sticking points.
Note:
While spec'ing hardware for app like this, I will usually have NI sales support verify the hardware will do what I want and provide an example program that proves the functionality I need.
I have never attempted to queue up an I/O reading 1/2 a Gig of data so you will be exploring limits I have never seen.
If the above does not work, then I suggest a "divide and conquer" approach.
This approach would use two DAQ boards and external clocking to acquire half the data on one machine and the other half by another. One of the boards should sample on the rising edge of a clock, the other system acquires on the falling edge. The resulting data would then have to be merged to give you all of the data.
NOTE:
The preceding technique should work but it will not be simple to implement.
I will watch this Q's to see if you have any issues. Please let us know if you figure this out and any techniques that made it possible.
Trying to help,
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(3,045 Views)
After reviewing your response to Dr. RT's reply, I see the above suggestions are invalid!
Ben
(3,045 Views)
Although LabVIEW RT is not necessary for your situation, please see the response to your question in the High-Speed Digitizers Forum.
Grant M.
(3,045 Views)
