String Comparison
I want to add a start mark for the sensor signal. So I added a 'T' as the start mark. In my program, I will compare the string from the serial port with 'T' to judge, if the sensor data comes from the next measurement. But I have noticed, although the string from the serial port is 'T', the result of the comparison is 'false'. Could someone explain it?
Best regard
(5,612 Views)
Can you save the serial output so we can see what you are comparing? You can also try right-clicking the string control and changing to '/' Codes Display to see if you are also picking up the termination character.
(5,593 Views)
Hello Matt,
thanks for your replay. In this project, I will use LabVIEW to communicate with Arduino. The serial output from Serial Monitor and LabVIEW VISA is like:
T
1023
985
897
765
732
T
1024
988
898
765
732
It is like so, there is a 'T' as the start symbol for every five measurement data. In LabVIEW, I could read the start symbol "T" from the serial output of VISA, but when I compare this 'T' with another 'T', the result is false.
Best regard
(5,575 Views)
Accepted by TUDarmstadtLLX
You likely still have the Carriage Return and/or Line Feed in your read string.  Try adding a Trim White Space before the comparison.
Another option would be to put all of your measurements into a single message.  You can separate your measurements with a comma and end the message with the Carriage Return and Line Feed.
(5,551 Views)
thanks for your reply. Your idea sounds feasible, I will try it out.
Best regard
(5,543 Views)
