String Concatenates with every interval? How to clear this?
My VI is attached.
How do I stop this string from concatenating on each run?
I just want it to be 6094012E.
Every time I run, "string" keeps concatenating-
etc...how can I stop this? Thanks in advance.
(1,615 Views)
Because even though your code looks like this:
It's actually wired like this:
So your shift register is uninitialized, which feeds back the last value each time.
Just fix the wiring and add an empty string to initialize it:
(1,599 Views)
Also I don't know if you need any of those intermediate steps, but if you don't, this is a much easier way to get to the hex string than what you did:
(1,592 Views)
