String Operations
Hey all,
Help needed to optimize the attached vi.. Suggest me any better idea?
(3,393 Views)
You could combine all the Concatenate String primitives into one large one.  Is suspect that the compiler is smart enough that you would not see much difference in performance.  I prefer to only put one instance of a constant on a diagram and wire it to all the places it is used.  Then if you need to change it, you only need to do so once.
What you have is easily read.  The combined concatenation has lots of wires and may not be as clear.  This is your choice.
Lynn
(3,388 Views)
Accepted by topic author Stephen.J
I am a Format Into String fan myself:
(3,381 Views)
Can you post this in 8.6.
(3,372 Views)
Not Needed..  Thanks Darin
(3,362 Views)
