String Processing
Dear Friends,
I have a string say "A1,A2,A3,A4,A5,A6" which is delimited by comma (and It will be received through serial port). I have to split the string and separate the values A1 A2 A3 A4 A5 A6 and put it in a array.
If I use split string I have to use 5 times (One output is a input for another). Is there any way to do it easily ?
Best Regards,
Rathan
(3,754 Views)
Spreadsheet String to Array. Set delimiter to ,
Felix
(3,747 Views)
Accepted by Pahee
use spreadsheet string to array
(3,745 Views)
Felix
Beat me by two minutes... 🙂
(3,743 Views)
But not with an image...
Felix
(3,738 Views)
Beat me, too.  That's because he cheated and didn't write the code.  😉
Bill
CLD
(Mid-Level minion.)
(3,735 Views)
