String concatenation and vi speed
I am trying to convert waveform data in .tdms into ASCII file in a particular format in order to be read by another software. The vi which I have written (attached) is able to do the job but at a very slow pace. In takes the vi approximately 20 minutes to complete a one second data (22050 samples). This us too slow as I am planning to work with waveform data at 1.5 million samples (takes 16 hours). I think the problem is attributed to the string concatination. Does anyone has any suggestion as how I can improve on this vi performance in terms of its speed. Thanks.
Running Labview 2011 on a window 7 laptop (i5 2.50GHz with 8G RAM)
Message 1 of 11
(5,175 Views)
Accepted by topic author Crawling
Sorry about this question.  I had it solved after removing the 'wait until the next ms multiple' vi from the loop iteration.
Message 2 of 11
(5,174 Views)
For some additional optomizations you can get a boost by using autoindexing tunnels and do your string concatinizations in one fell swoop (Yes, Concatinate String works just fine on arrays)
Message 3 of 11
(5,168 Views)
Jeff already pointed out some more optimizations, but here are a few more things that are wrong with your VI:
  • Your shift register is uninitialized, meaning that its contents grow with each run and eventually you will run out of memory.
  • Even with 1.5M samples, it will only a few seconds, so the progress bar is not really needed.
  • If you like simpler code, you could do something as follows (it is very slightly slower that Jeff's but probably worth it for easier code maintenance and diagram real estate.) 🙂
(I left the CR at the beginning like in your code, jeff move ot to the end of each segment. Not sure what you really want)
Message 4 of 11
(5,134 Views)
That is scary. does parallelism effect speed?
My code slightly faster than Christians? That has to be a compiler optimization bug. But, I'll cherish the moment.
Message 5 of 11
(5,121 Views)
Dear Jeff,
Thanks for the input.  By the way what is the vi connecting between the interleave 1-D array and concatenated string.  I do not recongize the symbol.  I believe it is to convert the 1D string array to string. The closest I could get in my search is byte array to string which is incorrect.
Message 6 of 11
(5,109 Views)
It is Concatenate, on the string palette.  It works on arrays.
Jeff posted a snippet, so you can drag that image to a block diagram.  Then use context help to hover over the functions you are not familiar with.
Message 7 of 11
(5,107 Views)
Actually Bill, that's "Interleave arrays". One of those resizable array functions that need a bit more press in core 1.
Message 8 of 11
(5,077 Views)
He was asking between Interleave Arrays and Concatenated string which I assumed he meant was the indicator terminal snce that is what the indicator was labelled.
Concatenate is between the Interleave Arrays and the terminal.
Message 9 of 11
(5,058 Views)
Silly mobile version.... Needs an inline viewer for images.   I appologize Bill, you are correct.
Message 10 of 11
(5,052 Views)
