String control and enter key
Hi, I use a string control as the password input box, but I found the Enter key is a input to the control too.
I want use the Enter key to inform the program password input is done, to trigger an event to handle the identify the password.
How can I do it?
Message 1 of 8
(11,401 Views)
right-click the string control and select "limit to single line".
Message 2 of 8
(11,398 Views)
Thanks, Can  I use a Click on enter key as an event? How can I use that?
Message 3 of 8
(11,349 Views)
Accepted by concorpoly
Jim
Message 4 of 8
(11,337 Views)
This is awesome! So simple...
Message 5 of 8
(10,656 Views)
What is the name of that search VI? How do I find VIs when all I have to go by is a screenshot? Chatgpt couldnt get it.
Message 6 of 8
(3,102 Views)
It's search 1D array
Message 7 of 8
(3,100 Views)
It's not a screenshot, it's a VI snippet (remark the upper part with LV version and date), that is an image with a vi embedded as metadata.
To load a snippet, save the image to disk and then drag the file to a vi Block Diagram. And voilà!
To generate a VI snippet yourself, select a portion of your code and choose Edit -> Create VI Snippet from Selection.
Paolo
Message 8 of 8
(3,068 Views)
